I have problem using any kind of software for listen my music, in every format. The problem is a very bad sound quality, like scratchs on ancients disks. The very strange fact is that if I use Windows Media Player I've no problem. I think this is not normal. I've this problem since the first day I've purchased the notebook.
hi, lourens.
i had the problem while playing games. problem was the autostart function of the sonic stage software - it automatically picked 5.1 sound instead of stereo. disable that, maybe it will help.
cheers
o-o-s
That's correct, Lourens. You'll probably find that you have sound problems with Quicktime as well. Just remove audio from the startup folder and restart the computer.
How do u do this???
go to start/all programs/startup and right click on audio filter and then chose delete. it wont startup when u log into windows next time
