Vaio VGN-NR21Z Battery Replacement
wilporta
I have a Sony Vaio VGN-NR21Z and the battery life has recently reduced to about 15 minutes.  I would like to get a replacement.
a.  Sony do not seem to supply the battery VGP-BPS9/B any more; is this correct?   It would be disappointing.
b.  Other vendors seem to require BIOS and driver updates to support a new battery.  Is this always the case?
Can anyone suggest the best aproach to get a replacement main battery?
Thalamus.
Champion
Hi wilporta,
You should be able to purchase a replacement battery from Vaio support to find the contact number click Support at the top of this page followed by Contact Us..
Then click on Vaio & computing..
Enter your vaio models serial number, which you should find on the bottom of your Vaio..
Then click Validate..
Then you should see the number to dial for Phone support..
3 REPLIES 3
Thalamus.
Champion
Hi wilporta,
vogler
Hi wilporta.
Did you have any luck with this? I'm in the same position and have drawn a blank with Sony so far...
Thalamus.
Champion
vogler@ab65 wrote:
Hi wilporta.
Hi volger@ab65,
Welcome to Questions & Answers..:smileyhappy:
Have you contacted Vaio support.?
If so were Vaio support not able to help you..:smileyconfused:
