Hi!
My problem is with the built in webcam on my VAIO laptop. Sometimes it just randomly doesn't work, it will pop up and tell me that the camera is 'in use by another program'. It even says this when I attempt to use the camera with the VAIO Camera Utility.. when I know that I haven't loaded any programs that would use the webcam. Usually a reboot works, although occasionally I have to reboot twice to get it to work 😕
Any suggestions?
Hi tekp,
Have you installed the Microsoft Hotfix KB931812.?
You can download the hotfix by clicking on the following link: Microsoft Hotfix KB931812 for Windows Vista
No I hadn't, I don't think.
Thanks I've installed that now, but as I say the webcam only did it occasionally so if it does it again I'll report back here
Thanks!
Hello,
I have the exact same problem; have you found that since you installed the update everything has been okay? It can be quite annoying at times!
Hey!
Yeah since I installed the update I haven't had any problems yay!
Although it might not have fixed it since it only ever did it occasionally anyway :S I'll post back here if it does it again though
So far so good!
Hello,
