VAIO RECOVERY HELP
VIPER
VAIO RECOVERY HELP
HI THERE,
I AM STUCK AS I HAVE FORMATTED MY HARD DRIVES AND DURING THE PROCESS I ALSO FORMATTED THE HDRR PORTION. FURTHERMORE I CANNOT FIND MY SYSTEM RECOVERY DISC AND AM UNABLE TO GET THE DRIVERS FOR NVIDIA GEFORCE GO 6200 SUPPORTING 128 MB. CAN ANYONE PLEASE HELP ME OUT OR SUGGEST HOW TO OVERCOME THE PROBLEM. MY SYSTEM IS VGN-FS115S AND I AM FROM LONDON.
KIND REGARDS,
VIPER
Blencogo
Hi VIPER,
What are you trying to do? Are you trying to reinstall the original XP Home SP2 operating system or are you trying to install a different OS?
If you want to reinstall the original OS and Preinstalled Software, you will need to contact Sony and purchase a duplicate Recovery Disc Set.
If you are trying to install your own copy of something like XP Pro or MCE, then you can download all the Drivers, Utilities and other updated software from here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FS&m=1810
If you are trying to install Vista it gets more complex!!!!
:wink:
