Vaio FZ 18L with Bluetooth Speakers?
hotdoc1
Hi
I have a Vaio VGN FZ1L with built-in bluetooth.
I have been think of buying bluetooth speakers but the literature says you must have A2DP compatible laptop for it.
I am unable to find any information about a2DP for my laptop.
Help!!
Nitin
2 REPLIES 2
tonybeard
Welcome to the forum,
Fraid not you will need a dongle via USB. If it doesn't display or list A2DP compatability then it doesn'thav eit. Only some of the latest Sony Ericsons say the W880i Walkman handset will give you A2DP connection but they cost a bomb. Try this but get a USB cable extention as the signal may need some positioning :slight_smile:
hotdoc1
Hi
Managed to get it to work.
Turns out the laptop is actually A2DP compatible but not on the list
Thanks for the advice
