Vaio Duo 11 GPS driver
profile.country.NL.title
1Casper
Hello,
A new GPS drier should be installed according to VAIO care tool. When I update the driver it is mentioned the update is failed. However no other explanation at all.
Does someone know how to oercome the issue or to analyse better the problem?
Thanks in advance,
Regards,
Casper
rich912
Hi Casper,
There is an ongoing server problem affecting some downloads with Vaio Care. This may not be the problem in this instance but if the problem persists over the next couple of days I suggest you contact support and report the problem.
Rich
Go n-éirí an bóthar leat
