Hi, my vaio is a VGN-A115Z i am having a bit of a trouble with my special buttons as the brightness light is on all the time and the volume buttons stopped working. Also the CD/DVD disc eject button doen't work anymore for some reason. Can anyone help?? Many thanks.
you should install vaio utilities for your model to get this buttons work.
Hi Rida19,
welcome to Club Vaio..
Download the Preinstalled Utilities from Vaio-Link, Use the following link: Sony Vaio Support preinstalled Utilities
Once downloaded extract the files and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..:smileywink:
Hi Knik777 and Thalamus, your tips did the trick. Many thanks.
You're welcome Rida19..
