Sony Viao - the Keys are typing incorrectly and including additional unwanted characters.
lismarch
I have a Sony Viao laptop - model PCG 61611M
When I type it includes extra characters, so for example what I have just typed appears as…..hwhwenz I ty2pe it inzcludeks extra chwaracterks, kso for example hwhwat I hwave jukst ty2ped hwould appear likes.
Can anyone advise , or help me to fix this please?
Any help would be much appreciated
rich912
Hi lismarch,
It would seem that you have a keyboard malfunction or cabling problem and unless you feel competent to disassemble the machine to check cable connections it will be necessary to contact a repairer.
If you have access to a USB keyboard trying this should confirm or otherwise.
If a new keyboard is required you will need to locate the correct product number as PCG 61611M is a chassis reference. You should find the product model on the screen surround or possibly on a white sticker on the underside of the notebook – it may start with VGN-
Rich
Go n-éirí an bóthar leat
rich912
Hi lismarch,
Rich
