I hope someon can help. I have a Sony VGC-M1 which I have recently reformatted. Most things work but I cannot have Vaio Zone or media. Eeach time I try to use these features I get the message that vaio entertainment platform is not installed. Can anyone tell me where I can get this download, I know I can get the upgrades but these are no good without the original programme and I know I can get it for Vista but I am running Windows XP Home edition.Please can anyone advise me
Hi Springtime,
I recently had the same problem finding Vaio Zone for my V2M. The only way I got around it was to extract it from my Recovery disc.
If you check out this thread: http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=37599 there are very clear instructions on how to do this. Just a tip; if you use the exact same paths to store your files in you can just copy/paste Philfree's example code into your run command, saving a few hassles!
Good luck!
Ex
