Recovery Media on initial start up - HELP!!!
trpatel54
hi, i have a sony vaio - VPCF13M8EB. im trying to create Recovery Disc's but when ever i try to burn the disc's the system fails with an error message. i have repeated the process about 5 times (different branded disc's). the drive seems to work fine as i have tested it by burning photos and videos.
can anyone help?
Tags (1)
Blencogo
I assume you have installed the new version of Vaio Care from Vaio Update?
If so, I can't think of anything else to try and I would contact Vaio Support to see if they have a fix - or as a last resort ask them to send you a Recovery Disc Set free of charge.
:slight_frown:
5 REPLIES 5
Blencogo
Can you tell us what the error message says?
Have you installed any other software like Daemon Tools or other Virtual Disk software?
What sort of discs are you using?  Usually DVD+R from Sony, Verbatim or TDK are favorites.
:thinking:
Blencogo
:slight_frown:
trpatel54
Hi, sorry i cant remember exactly. approx says 'Error has occured...the disc cannot be re-used..insert another disc and try again'.
I have used about 4 different brands (DVD-R & DVD+R).
I havent installed any software yet....just took it out of the box yesterday.
Even did a factory reset and tried again...still failed..have no idea what this is happening.
Thalamus.
Champion
hopefully someone from Sony should have contacted you..
Strzeb
i have the same/similar problem. i have got through around 10 discs DVD-R. Best result was complete disc 3 (out of 4). From what i can gleen from the web(which isnt much) something might be running in the background but i dont know what. McAfee was deactivated and firewall opened, and internet link blocked.
How do i contact Sony?
