pointer/ mouse device problems
fergadeth
the two buttons below the mouse/pointer device on my vaio FS515E are not working properly and sometimes not at all.
is this likely to be physical wear and tear or could it be driver related?
i apologise if this is an obvious question!
could someone point me in the right direction for a driver update?
its an Alps Pointing Device for VAIO....
any help much appreciated!
4 REPLIES 4
Blencogo
Hi fergadeth,
It doesn't sound good - the fact that it is intermittent means that it is almost certainly a hardware problem. It may be worth a poke around inside to see if there is a loose cable!!
It is worth reinstalling the Alps driver either from your C:\Drivers\Pointing folder or by trying to install the latest version which Sony provides for the SZ7-Series downgrade to XP. It will be the 8_POINTING.ZIP file available here: -
ftp://ftp.vaio-link.com/PUB/OS/XPDOWNGRADE/SZ7/DRIVERS/
I presume your Vaio is out of warranty. You could try ordering the parts and fitting them yourself but it looks like you will need the entire Palmrest Assembly at $160.57 plus shipping: -
http://www.nexttronics.com/catalog/sony/A/A1128300A.htm
It may be worth contacting NextTronics by e-mail to check if smaller parts are available - you can buy the buttons for $35.76 but I'm not sure what this includes.
I attach the FS-Series Manual in case you want to look inside for any poor connections.
:thinking:
fergadeth
cheers buddy
fergadeth
when i try to run the driver file, a message saying the following comes up..
"IOCTL_SetMouseEvent could not be found" any ideas?
i dont think i will risk taking the comp apart... dont wanna bugger it!!
it is out of warranty, yes
fergadeth
got the driver installed
buttons still not worki well
gonna have to think about investing in a mouse sometime soon it seems !
cheers for the help,
