hello, thank you for your help.
I got Vaio PCG-7D1M, bought from Sony "recovery set disk" to get original notebook status.
It worked fine.
Now notebook doesn't work properly and I'm attempting a new restore to original status using Sony recovery set disk.
When I try to start recovery procedure, after some minutes, I get an error message regarding "not possible read image file" "errors on flow reading" "Try to execute again recovery procedure".
I thought to change hard disk, I changed 2 more hard disk (Toshiba, Fujitsu, Samsung" but the result was the same. I tryed different recovery procedure from Sony disks (recovery only C, recovery C and D, Total recovery) nothing changed. Same errors message.
I tryed to format disks on a different PC ... nothing!
Any solution to solve this quest?
Thank you to all
