Hi there all S vaio people, its my first post here....
Im having trouble with the motion eye camera on my new Sony Vaio VGN-FE41m Vista OS laptop.
One day it was working, then the next day it stopped working, with a notification stating the camera is being used by some other program.
It seem to do this once i installed msn live.
I did restart once, and the vaio rolled back to a restore point and the camera started working again, then i had the confliction again and it stopped working.
Ive searched these forums and i see this problem with the built in motion eye camera is quite popular on a few other sony notebooks.
Ive read quite a few post regarding this problem here but, i don't seem to find the solution/answer in the posts ive read.
If there is a fix or someone has actualy got a cure or the remmedy for this "the camera is being used by another program" problem, could you post a straight answer please.
Regards to you all
Hi Freako and welcome to Club Vaio.
This seems to be a Vista Driver problem and we are waiting for an update from Sony. It seems most people with Vista have the same problem.
Have a look HERE
Have a look HERE
Hi Freako
Yes this motion eye problem with vista seems quite common.
I have the exact same problemm as you on the VGN-FE41E. I was recommended to download
the VAIO Camera Capture Utility update but still no joy..
Looks like we have to just sit tight until Sony publish a fix!
Hope it's not too long...
Regards
Ellie t
