How do i turn down the brightness on my fx 805 laptop
A simple search on brightness at :arrow: VAIO Link produces the :arrow: following results.
Of course the instructions are in your manual. If you managed to lose your manual, it is available in Adobe Acrobat format at VAIO Link.
just press FN Shift and the brightness key, (F5)
