Hey im running Vista on my ar21s before when i use to run windows xp(mce) sony provided a software from microsoft along with it, which converts music file types... i think it was under windows enhancments, anyway ive been looking everywhere for it but i dont seem to be able to find it, ive even explored the pre-installed driver/application but couldnt find it, does anyone have the name and knw where i can download it?
LOOKING FOR A THREAD I CREATED FEW WEEKS AGO ABOUT GETTING THE BLUE SCREEN UPON SHUTDOWN, I DONT SEEM TO BE ABLE TO FIND IT, IF SOMEONE KNWS THE LINK MAY PLZ POST IT THANK YOU!
anyone?
It's 'Image Converter 2 Plus' you are looking for I think.
http://club.vaio.sony.co.uk/clubvaio/GB/en/exploration/software/
I don't think IC2P is Vista compatible - it certainly is not installed on newer models. Sony Style used to sell it but it seems to be discontinued.
A Google will bring up several free alternatives.
Ive seen free alternatives but there not that good, the one that was provided with my AR21s was beautifull, the ones that come up in google search are slow and convert with distortion
