How to use DVD-RW
GoodMusic
How to use DVD-RW
I want to use rewritable DVDs on my SZ1XP with Matshita UJ-832D drive, but can't see how to do it. Do I need to buy third party software (suggestions?) or is there somthing under the Vaio menu that will do it? BTW I just want to read and write files, not create videos with singing and dancing menus.
Thanks in advance for any help.
3 REPLIES 3
Thalamus.
Champion
Hi Good Music
Your Vaio SZ1XP should have Roxio DigitalMedia SE 7 pre-installed, if so this program would allow you to burn DVD-RW disc's.
GoodMusic
Much appreciate your help Thalamus, thank-you.
Some of Roxio was there. I uninstalled and re-installed and it works.
For anyone reading this in the future, you can burn, erase and re-burn a DVD-RW in its entirity with the pre-installed version of Roxio, but you cannot add or delete individual files without erasing the whole DVD. There is a $70 upgrade to give full r/w capability.
Thalamus.
Champion
You're welcome Good Music, glad it worked.. :slight_smile:
