Hi I need help with PCG-K315S
MAGAYVER
My sony vaio its turne off just after logon do windos, the coolers ar clean and work fine, the battery is out, Im use just the charge , someone can help me please.
jumpsuit
Hi there
Are you running XP?
If the vents / fans are clean then it could be a couple of other things.
Are you able to get into safe mode?
If so can you run a virus scan?
There was a virus that used to cause this:
http://www.iishacks.com/2010/02/24/windows-xp-shuts-down-after-login-pc-off-bat/
