can some1 help me locate drivers for vgn fs285h on xp professional, as the drivers from vaio do not seem to work for my ethernet, mass controller and i cant get my nvidia geFor go 6200 to mount either? any help would b greatly appreciated
woz60@hotmail.co.uk
Hi Rude_boiy.
The Preinstalled Drivers and Utilities on Vaio-Link should work with an XP Pro installation on your Vaio.
Have you installed ALL the Utilities in order?
Have you expanded ALL the drivers to a directory C:\Drivers and tried to install them manually using Device Manager?
thnax for dat advise i have sorted it out now but still have a small issue. My 8o gig harddrive has been partitioned so that i can run kubuntu linux in a dual boot setup kinda way. whilst reinstalling xp professional i seem to have lost the bios and the dual set up, is there any way to regain this, ma computer seems to go stragit into windows xp everytime i load up !
