Help needed please.no power to my laptop
coleraine
Help needed please.no power to my laptop.I pluged my Vaio into my car adapter today to use it on my GPS.the adapter was set at the right voltage but the wrong polarity,and something popped.Now the power cable wont charge or work my laptop.
Please help...
Model is VGN S2HP
12 REPLIES 12
coleraine
yes it powers up on what left of the battery charge,but it wont recharge the battery or run of the mains...it runs ok on the battery now but when it runs out,it wont recharge it.I did smell a little burning.but it still works on battery..HELP PLZ
MattWilson
Hi are you here to help me,Is there away to undo the BIOS password,remove the cmos battery,If i had the motherboard service manual,I am sure i could repair it myself knowing what capasitor has blown.
£200.00 to repair a faulty blown power supply.
I need help .so do you just want me to pay out lots of cash for a repair,that i guess can be done much cheaper.I guess you work for SONY.
Only Tweety2B is a sony employee and he runs the fourm.
All members are joe public.
Its up to you if you want to have a go at fixing it yourself then go ahead but if you get it wrong you risk causing more damage and then have to spend out more money to get it fixed.
:slight_smile:
Thalamus.
Champion
Hi coleraine
I have sent you a private message
