Help, my computer clock goes AWOL
derek0349
I have just bought a superb Vaio but the computer clock has a mind of its own! It never keeps the correct time and the date is constantly changing on its own. Any ideas how I can correct this?
3 REPLIES 3
Blencogo
Hi derek0349 and welcome to Club Vaio.
What have you tried? Have you set the Date/Time/Time Zone? Are you connected to a Time Server?
Run through this procedure: -
http://www.ehow.com/how_2056384_change-date-time-windows-vista.html
If that does not work, come back and tell us when this happens - is it when the computer is first started? It could be many things like the CMOS battery but I expect it will be something simpler.
:wink:
derek0349
I have tried everything suggested. The clock and date is wrong everytime I log on to the computer. It is fine while it is running but when I shut down and open up again it is incorrect.
Blencogo
It sounds like the CMOS battery, which keeps the time when your Vaio is powered down, is either faulty or has a bad contact.
You will need to contact Sony Vaio-Link Support here: -
http://support.vaio.sony.co.uk/contacts/contacts.asp?site=voe_en_GB_cons&tp=vaio&cm=phone&cc=UK
Or if you have just bought the Vaio, take it back and ask for a replacement.
:slight_frown:
