Hello there, I have the above mentioned Laptop and am suffering from Burning issues when using CD or DVD.
Last night i did a full restore to when the machine was new and the problem still occurs, Ive done all official updates etc.
Strange thing is it happens if im trying to burn with the built in Drive (DW56A) or a External Pioneer DVR109 drive from the USB2 Port??
Basically it gets half way through and says ERROR and kicks the disc out... with the factory installed Stomp software it gives this message as the fault..
Sense: 03 ASC: 0C ASCQ: 00 (Command 2A)
Px.dll: 2.0.60.500
pxdrv.dll: 1.1.23.0
pxmas.dll: 2.0.60.500
PxWave.dll: 2.0.60.500
PXWMA.dll: 1.0.0.3
Any ideas?
I would try alternative disks first, I would then try using a cd laser cleaner.
If neither of these work then there is a good chance that the drive is worn out or faulty.
