Disc recovery
redofr
Disc recovery
Hello
How many disc recovery could be created ? Is there a limitation ?
5 REPLIES 5
Thalamus.
Champion
Hi redofr,
welcome to Club Vaio.. :slight_smile:
I don't think there is a limit to the number of recovery disk sets that you can create..
I would think two sets would be all that you would need to create though..
redofr
Is it possible to create a recovery disc with a DVD dual layer or
DVD RW ?
Thalamus.
Champion
Hi redofr,
Yes some Vaio have the option to create recovery disc's using DL DVD disc's but no not DVD RW disc's..
redofr
All right however if there're no options how can we do ?
Is the software application upgradable ? Because i was thinking of the BIOS
or a patche that could be downloaded .
Thalamus.
Champion
Use standard DVD's or CD's
No the Vaio recovery utility as far as I know is not upgradable.. :slight_frown:
