- Ctrl+C and Ctrl+V not working
brstaal
Hi There.
I have a Sony Vaio VPCEB1S1E, that I have some problems with.
The problem is that Ctrl+C and Ctrl+V is not working anymore, I has been working before as this is not a new PC, but suddenly the keyboard shortcut's has stopped working.
I know now that it's most likely not the windows installation as i have done a clean install, and the shortcut's still wont work.
I can copy paste from the mouse, but not the keyboard.
Odd thing is actually that ctl+X works, and if I use the right CTRL key then I can get Ctrl+V to work, but the left wont.
Did a test with a external keyboard where ctrl-C and ctrl+V works just fine
Any idea as to what is wrong here ?? I'm getting deperate here, my life is so much easiere with thows shortcuts.
0 REPLIES 0
