Control panel and System info showing different cpu's
SSBx
When I go to the control panel -> System & Maintenance (or whatever it's called in english) it says I have a T7100 processor at 1.8 GHz...which is what the system spec should be on my VGN-AR41L.
However, when I go to the control panel and check under the device manager, and check the "Processors" it says I have a T7500 2.2 GHz processor.
Which seems weird to me. Anyone else get this? And why? And what's the correct value? I'd assume it's what the system spec says.
3 REPLIES 3
kee-lo_
Sisoft's Sandra program can tell you exactly what processor you have.
SSBx
Interestingly enough this is what SiSoft Sandra has to say:
Model: C2D, T7100@1.80GHz
Name: C2D 65nm 2.4-3.33GHz
Speed: 1.79GHz
So it seems they missnamed it?
kee-lo_
Just shows you that you can't trust Windows to report things correctly.
