I just bought my notebook last week (vgn-fz11s), but some of my programs don't work in vista so I had to install xp instead.
since I have installed xp my computer sound is not working.
I tried these options:
kb835221.exe
kb888111.exe
STDAUD-01108005-UN.exe
also I installed the audio driver for VGN-FE31M which has similar audio card with mine but none of them works:((((
Also I have got another problem with my pci controller (memory stick)as well and I could not find any driver for it!
do you have any suggestion???!!
regards
Hi greentree and welcome to Club Vaio.
Download the Drivers for the VGN-FZ19 Vaio (which is the same as your FZ11S except for the Graphics Card) from here: -
ftp://ftp.vaio-link.com/PUB/OS/XPDOWNGRADE/FZ19/
Extract the files from the download and install the Memory Card Read/Write Driver from Device Manager(Texas Instruments FlashMedia Controller Driver).
You can also try the Audio Driver in FZ19_Drivers\Audio\2\Setup.EXE
Hi Blencogo,
Thanks alot for your help
My sound is working now
but I still couldn't open my memory stick card just the memory stick icon appeared to the system.
regards,
