hi guys
i hope you can help with this. When I am playing movies on my vaio the screen was very dark, so I have changed the catalyst control centre (in the video section) to use application settings but when I restart or put the laptop to sleep the video preset reverts to standard.
So far, i've tried re-installing the catalyst control centre and saving my settings in a profile but with no success, does anyone know anything else i could try?
It may be a problem of your control center version try updating it.
To find the newest version of the Control Center go to http://support.amd.com/us/gpudownload/Pages/index.aspx?src=CCC-CheckForDriverUpdates and choose your graphics model.
Hope this helps ,reply and let us know what happened.
Thanks pankoto but I can't download those drivers they are for non OEM cards
You can dowload and install the control center regardless of an OEM or a non OEM card.
My card updates its drivers only from VAIO but the control center can be updated from the AMD site, I tried it to solve problems with my control center (It works without any problems, also you can dowload and install hydravision from there).
Write a reply and tell us what happend.
Hi pankonto,
Thanks for your help, I've downloaded the CCC from AMD and it sorted the problem
