Wall mounting a small 24W605 tv
JADASTIC
Hi, I've just purchased the 24W605 and I have attached it to the wall using the brackets supplied. But I now find I want it cantilevered off the wall so that I can see it from our kitchen table as well. Does anyone have a suggestion for a wall bracket that would do the job, it seems Sony don't make one.
Anonymous
Hi there
As you may have guessed, the W6 series does not have the standard VESA holes to connect to a normal wall mount.  Unfortunately, there is no easy solution to this problem that for some reason Sony decided to create.
There is no off-the-shelf solution either.
I have heard it talked about on the AV Forums that if your clever enough, you could engineer your own bracket mount using a panel of wood or metal.  You could mount the TV onto a piece of wood or metal (using Sony's bracket), drill a few standard VESA holes into it, then mount that onto a VESA compatible wall mount.  Not an ideal solution (or easy infact) - and I would assume not recommended by Sony either.
2 REPLIES 2
Anonymous
Hi there
JADASTIC
Hi there thanks for the suggestion. I think I had already come to the conclusion that 'wood' will need to be used somewhere, but your idea is a good one, will give it a go.
