Sony KDL50W829BBU - MOTIONFLOW NOT WORKING...!!!
Abs827
Hello, i brought this tv when it was first released a few months back.
The problem that i have is that I'm getting motion blur and judder when watching football and fast moving scenes.
When new the picture was perfect but now its getting annoying.
Also a month back the tv would not turn on properly. It would turn on with a purple screen and a black bar down the middle then switch off after a few seconds and then ambi light would start blinking red.
Dont know if this could be causing the problem. I have read somewhere that this could be the power board on the tv.
Any help in what i should do...?
Anonymous
Hi there
To be honest, your first point of call should be the retailer you purchased the TV from and either arrange a "swap" or replair. In regards to the "blinking red light" depending how many blinks indicates what type of fault.
My advice, contact your retailer and explain to them the problem, lay it on in regards to the redlight / purple screen etc, as they may not know what "motionflow" (obviously mention it though including the "juddering" etc)
