Sony kdl-42w705b horizontal lines
Rybaak7
I have a problem with my sony lcd tv. At first, I realized that the picture shows horizontal black lines divided at about a quarter inch intervals. The black line fades as it approaches the right side of the screen. The lines don't cause a shadow, but it seems to reduce significantly the definition.
Since it doesn't blink, it seems to be different than other issues. Could this be a power supply board problem? Please tell me it is not a bad display. I purchased this back in August 2014. Tried to reset the tv, but nothing.
Please help. Photos attached. Not noticeable enough if I take a pic of the entire screen.
5 REPLIES 5
Anonymous
Hi there
I think you might know the answer, but it appears that your TV has developed a hardware fault.  Your best bet is to contact your retailer you purchased it from and claim a warrantee repair.  All else fails, contact Sony Support for them to arrange a repair for you.
I have the same exact issue.
Ciuld you please tell me how did you solve yours?
Anonymous
Hi there
This would be a hardware fault, likely to be the T-Con board and/or LDVS cable.  You will need to contact an authorised Sony repair centre.  See HERE
Cheerx
mpsandrac
I also have this problem with my tv which is 18 months old.
Anonymous
Hi
Same advice as the others - You will need to contact an authorised Sony repair centre.  See HERE
