Sony Bravia KDL-55W815B extrenal HDD
Hello, please can you help me with buy external HDD (or SSD disc) to buy?
It is because of I need to record tv programs and I dont know wich hdd or ssd will be the best. I found that only 32Gb up to 2 Tb of space is an option, but no detailed informaton about hdd tranfering speed, etc.
I will be very happy for some feedback.
Thank you and have a nice weekend,
Milk
3 REPLIES 3
Pascale_F
Moderator
Hi Milk,
Welcome to the community.
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Marino.Manolo
USB memory or USB SSD Hard disc are not supported for recording function.
Please use normal USB HDD hard disc for recording Digital Broadcast.
https://www.USB memory or USB SSD Hard disc are not supported for recording function. Please use normal USB HDD hard disc for recording Digital Broadcast.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-55w815b/articles/00078329
According to the USB 2.0 standard, the maximum theoretical transfer rate is 480 Mbit / s.
The_Black_Rose
Specialist
Hi Milkovone81 ,
I've checked the Sony website and I found this article : https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-55w815b/articles/00115... , it does explain all of the requirements but it doesn't state a specific model so I think Sony doesn't recommend a certain model. I believe that this means that whichever model matches the requirements should work.
Cheers,
The_Black_Rose
