Smart Tv Response Dead Slow
lookforsumit
Hi Friends,
Happy New Year to all of you ...
I have bought new 40HX853 . The SEN is very slow . Also the response time it takes to load is very slow. Is this specific to my TV . I tried using BBC IP Player .Although it did work but while typing , forwarding and reversing the response time was dead slow.
Can anyone help me rectifying the same or point me to right direction OR should i return the product
senkanda9
Not sure, But check your internet speed which might be a problem as well.
http://www.broadbandspeedchecker.co.uk or check in with your internet provider
