Removal of VEWD TV Store
I notice Vewd is going to be removed from my Sony Tv.  Is it going to be replaced with something else? If not how am I to download apps I want/ need??
Tags (1)
155 REPLIES 155
Win_88
Specialist
If refreshing internet content doesn't work, I'd recommend trying a factory reset in this case.
I hope that helps
Win_88
profile.country.MK.title
Zoki84
Hahahahahahh, are you ok? From where did you fall here?
FinnishPenguin
Does anyone know if it's possible to install some Linux programs/apps on the TV somehow? Are there any other HTML5 app stores that could be used with the built-in browser?
Zoki84
A a no you are withorh any apr you have stupid tv nor smart , yoy 7ndederstant that?????
FinnishPenguin
The devices run on Linux, so theoretically it should be possible to install programs (if there are any compatible ones), or run them from a USB flash drive, if one manages to get root access by exploiting some vulnerabilities. There is of course a risk of bricking the device and I'm sure it voids the warranty as well.
Another option would be to run HTML5 apps through the browser, so then it wouldn't be necessary to install anything. That's why I was wondering if any free HTML5 app stores exist.
profile.country.SE.title
Marwan5685
You are talking about something Smart ,, not Sony.
Zoki84
There is no browser you cant open html5, and please reed before writing
dutchice
Hi @FinnishPenguin,
Welcome to the Sony Online Community!
Yes there are some alternatives indeed. Please read this post:
https://community.sony.co.uk/t5/other-tvs/removal-of-vewd-tv-store/m-p/2628653#M52631
Cheers,
Dutchice
Zoki84
You are an expert?
bilgimemet
Hello there. I'm from Turkey. I have the Sony smart TV KD-49X8505B. My applications also disappeared. It doesn't work. Change DNs, restore factory settings, update application etc. I did it all. There's only 18 of them left. Even though I have returned to factory settings many times.
