- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have just purchased a new Sony KDL-46W905A today. I cannot get the Netflix app to connect. I click on app and it gives me error NW4-8. I have been in contact with Netflix and they can't even sort it. Internet is fine - just can't connect to Netflix servers. Has anyone any ideas it's driving me nuts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@krs360
Hi there
I probably should have checked this first, but it appears that there is a known issue on the WD6 range and is currently under investigation. However the information I have is that these IPTV services dont work at all - no mention of it crashing the TV (or force rebooting)
Symptom:
The symptom occurs after an IPTV service has been used (such as YouTube or Netflix), and a customer wants to switch to BBC iPlayer or an HbbTV service afterwards. The BBC iPlayer / HbbTV service cannot be launched in this case.
Work-around?
A possible work-around is to unplug the AC power and launch the BBC iPlayer / HbbTV service without launching any IPTV services first.
Im going to highlight this back to Sony as the TV appears to reboot in your case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I came across this thread looking for ways to get apps including Netflix working again and I know it's an old thread. I have a 55XD9305 which worked fine until yesterday. Suddenly on a wired lan connection and stable 51Mbps internet the pre-installled apps like Netflix won't open or start, play for ten seconds then spend twenty seconds or so buffering ad nauseam. I've narrowed it down to the TV because the internet is OK, other devices work with the internet - even my Sony BluRay can stream Netflix - but not the TV.
As Netflix is an integral part (pre-installed, dedicated button) part of the TV I'm worried it might indicate a problem with the TV. If that sounds an over-reaction our 2015 Sony 4K never worked properly so Sony refunded us. We bought a 2016 model thinking the bugs would be sorted but that TV died completely after six months. The retailer replaced it with this one which has this problem after only three weeks.
Any ideas about what's going on gratefully received! Or do I give up entirety on Sony? I'm reluctant to reject this set unless I have to as the 4K panel is great.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
that on my hard wired network.
I also find the inbuilt WiFi randomly turns itself on so perhaps this has
priority over wired and if it's not set up would leave you not connecting.
Also now and again mine won't go on the internet unless I give it a power
cycle ie pull the plug out
Other than that my 4K Sony TV works flawlessly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks installed the new firmware and Netflix now works. I have to say the Sony Tech Support centre in Cairo has improved immensely and give credit to them for their assistance as well as Quinnicus.
Only problem is that now since the update Sky Q can't see my TV as a 4K TV!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a Sony Internet TV model NSX-32GT132 I have the Netflix app and was working well until November. I did not used the app in the month of December but now that I am trying to connect to Netflix but it saids is unable to connect me and advise to contact Netflix. I contacted Netflix and my account is active, I do have internet connection as I can use Goggle. However once I am in the page the keypad is not working. So I assume I have several problems. Can some one in Sony help me!!
Thanks!!!
Maricarmen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @mcgarcia
What country are you located in? Also the model number is just NSX-32GT1
Have you tried removing the device from your netflix account?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried everything!
Called BT
Called Netflix
Followed all help guides
followed all solutions
Nothing.
Then a year later, we figured the problem out after buying a TV which uses another server and by coincidence and luck -we figured why our netflix button was not working giving errorsnw-2 and what not!
You have to unfortunately delete all parental controls and web protection on your BT account. (Log in, go to " your extras' and deactivate-from a PC!)It can take up to 24 hrs for this to deactivate .Then the netflix button works excellently!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried everything!
Called BT
Called Netflix
Nothing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
tried everything!
Called BT
Called Netflix
Nothing.
