Hi, I just bought the BDV E670W blu ray home theatre system and would like some advice as to which TV would best compliment it??
well it should have been the other way round really, it depends personally if you want a top notch tv with pretty good 3D capabilities then the HX853 is a very good place to start, this is also the tv of the year too so you wont go far wrong there.
