Feature not available with current input mode
henryjohnson528
sony bravia KLV-40W672E . i can't change the screen size .when i try to change to it with the icon on the remote ,the message " Feature not available with current input mode" is displayed  and the screen size settings is greyed out in the system settings . help me
5 REPLIES 5
Mick_D
Moderator
Hi Henry
Could you please give us a bit more information about the device(s) you are using as inputs when this message appears?
Meanwhile, you may find this Support article helpful.
Mick
henryjohnson528
The standard remote i got with the tv and i use it to watch movies on my
usb pendrive
Mick_D
Moderator
Hi Henry
The problem could be the pen drive and/or the movies you have on it, which don't provide the necessary formatting information that would allow the TV to re-format or re-size the file to match your display.
You may get a different result if you plugged the drive into another device, like a DVD or BluRay player, but it's difficult to be sure without knowing more about your set-up.
Sorry I can't be of any more help.
Mick
Just initialize your tv it should work dont reformat with initializing you just lose a few settings
why_give_my_username
Same problem. I downloaded Vinesauce Joel's videos ''The Sims 4 Meme House'' from my Windows 7 computer. When I played the video and tried to fast forward it a message appeared saying: Feature not available with current input mode.
This is not urgent but its annoying.
