- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I am trying to connect my Toshiba laptop to my Sony Bravia KDL 32EX703 so that I can use a flight simulator software. I have tried a TV out connector to USB, this did not register. I am told that I can connect using a DVI connector from the external monitor connector to HDMI and this will work but I need to know whether the DVI connector, a Super VGA HD15, Analogue only unit to HDMI will work? Can I use a Super VGA HD15 connector to DNI-I/ HDMI connector and then plug the HDMI into the television.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Mickaj and welcome.
Exactly what outputs does your PC have?
If it has a VGA 15-Pin Monitor output - so does your Bravia and you can connect using a VGA Monitor Cable. If you need sound you will also need a cable from the headphone socket on your PC to the VGA Audio-in socket.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Blencogo
Many thanks for this. Yes my laptop has a 15 pin DVI VGA output and an audio out socket so I will try it.
I have now checked the back of the TV and it has the same 15 pin VGA.
Again, many thanks.
Mickaj
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am not able to connect my toshiba laptop with bravia TV as there is no HDMI port in my laptop, Tried to connect with convertor( HDMI to VGA) but notconnected, need to guide me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
What model TV do you have?
On your laptop, do you have a DVI connection or just VGA?
Also, what type of HDMI to VGA converter did you use?
