Brightness and menu
M666MOC
Brightness and menu
I have a Sony LCD Projection TV model KDF-50E2000 or KDF-50E2010. For some time, the picture on it has been very dark, and I cannot make out any of it on night scenes, for example. I have tried going to the menu to adjust the brightness, but when I click on Settings, then Picture Adjustment, all that comes up is the first two categories, Picture Mode and Contrast. Whatever arrows I push on the remote, I cannot access the other categories including the Brightness one I need. Is anyone out there able to tell me if I am doing something wrong, or if this is a recognised fault, and if there is anything I can do about it. I'd be very obliged for any help or advice. Thank you.
2 REPLIES 2
Anonymous
Hi there
Sounds like you need a new lamp for your RPTV.  See page 33 of the manual HERE.
Lamp model you need is: XL-2400
M666MOC
Thank you for your help. I've ordered a new lamp and will have a go
at fitting it -- it doesn't look TOO difficult!
Best wishes,
Michael
On 23-04-2016 18:52, Sony Community Mailer wrote:
> Hi M666MOC,
> Quinnicus (Expert) posted a new comment in Televisions [1] on
23-04-2016 19:52:
> Hi there
HERE [2].
> Cheers
> THIS
IS AN AUTOMATED EMAIL. PLEASE DON'T REPLY TO THE SENDER OF THIS MAIL.
PLEASE POST YOUR REPLY IN OUR FORUM OR USE ONE OF THE LINKS BELOW.
* You can RESPOND [3] to the comment
> * You can ACCEPT THE SOLUTION
[4] to the comment
> * You can GIVE KUDOS [5] to the comment
> Sony sent this message to
mpoc@waitrose.com [6].
> You are receiving this email because a new
message matches your subscription to a topic. To control which emails we
send you please go to, manage your subscription & notification settings
[7]
Links:
[1]
http://community.sony-europe.com/t5/televisions/bd-p/tv_en_1
[2]
http://pdf.crse.com/manuals/2695226111.pdf
[3]
mailto:sonyeu1.prod|22b20d2d|191fb043-39e8-41a0-851d-516434a3c224@reply02.lithium.com?subject=Re:%20Brightness%20and%20menu
[4]
http://community.sony-europe.com/t5/action/replybyemailactionpage?replybyemail.action=sonyeu1.prod%7...
[5]
[6]
mailto:mpoc@waitrose.com
[7]
http://community.sony-europe.com/sonyeu1/user_subscriptions
