Bravia smart and you tube
@3261462401029253
My Bravia kdl40hx75 smart will not connect to you tube as it asks for a user name and pin which I can't locate. Is it something to do with google and you tube?
warmstrong99
In a word - Yes.
Youtube is part of the Google empire.  Whatever username and password you use for Youtube - use on your tele.  If you don't have an account - set one up.
warmstrong99
In a word - Yes.
