Xposed Framework
Ovush
Xposed Framework
Hello, I have a rooted Xperia V phone.
Will it be a good idea if I install Xposed Framework ?
Is there any complications ?
6 REPLIES 6
Ovush
Thank you Slightly_smiling_Face
Thommo
I use Xposed so it depends on what you are wanting from it
Anytime Slightly_smiling_Face
Ovush
I want to install some android l features
Thommo
To use Xposed you need Root and Busybox installed then install the Xposed Framework and then you can install the modules
