Xperia X8 Flashtool debrand and unbrick
Special Thanx the XDA forum hurikan23 and Blagus
you need
1) Flashtool
http://forum.xda-developers.com/showthread.php?t=920746
or
http://androxyde.github.com/Flashtool/
2) the firmware
2.1.1.C.0.0
http://www.mediafire.com/?ger8hxbxfxw9w9o
2.1.1.A.0.6
http://www.mediafire.com/?5tb64hyrin6aa1c
or
http://www.mediafire.com/?d3pobqqc3py66#4c02265ox4l1r
it's useful to have
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
http://www.youtube.com/watch?v=yg2dYQO59CQ
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
W251bGwsMSwxLDEsImNvbS5tYWdtYW1vYmlsZS5hcHAuYXBraW5zdGFsbGVyIl0.
open "Apk Manager" and voila select the apps that you wan't to install
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
go to settings -> applications -> check unknown sources
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
Use one of these links to download the
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
Install it and you will see 5 folders
Custom
Drivers
Firmwares
Loaders
X10Flasher_lib
take the firmware to the "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
This is an step by step guide
Make sure you backup everything
or
How to install it
You need to
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
it's useful to have
now on your phone
or
thanks uliwooly great post
How to USe Flash TOOl and How to Unlock Bootloader using Flash Tool : A Compete Tutortial is available for Sony Xperia X8 Users.
If ypur phone is dead then ypu can also repait it buy flashing original firmware using fladhtool.
For more information : http://www.thewebuniversity.org/2013/12/how-to-unlock-bootloader-on-sony-xperia.html
hey man...
I did flash your stuff here Flash Tool said: success please reboot but now my phone is DEAD 100%!!! doesnt start... not even a light shows when plugging a cable in... what did I flash here that destroyyed my device!!!?!?!
That's quite odd, you could let it charge for couple of hours and then repair it with PC Companion
i tried.... 3-4-5 hours nothing.. I also put the battery into an external charger an charged it to 100%!! still nothing happening!!! is there anything else I could to do?
why did this actually happen?!
