Xperia v won't boot (turn on) help!
kelvinnhowe
Hey everyone, I bought a Xperia v mobile recently and yesterday I tried to updated the os from ice cream sandwich to jelly bean. I turned on wifi and battery power was on %60 percent. Everything went well and the os download finished as well. It started updating nicely. After the update finished the phone rebooted. the phone started nicely showed those colors which appear when you turn on a phone but this time they weren't of the ice cream sandwich, they were of the jelly bean os ( some lines appearing from left to right with colors red purple blue orange and green. Now the phone just froze just after showing those lines about 3 times. I waited 3 hours and the phone was just like that. I thought to my self " an os update shouldn't take this long so I removed the battery. I put it back into the phone and powered it on. Now it doesn't freeze, just turns on, show those colors 3 times and it reboots again. If you might assist please let me know how I can fix this problem. Thanks in advance
5 REPLIES 5
kelvinnhowe
thanks so much, worked perfectly and im very happy with the update. I still have a question though, I'm a gamer and I got myself a 32ghz memory card as my external memory since I wanted to install huge games on play store e.g asphalt 8, fifa 14. these games require alot of space to install. my question is, is it possible to install these games and apps to my 32ghz memory card since the Xperia V only have 5ghz of space? right now I only installed 2 huge games and thats my limit to the 5ghz memory on the phone. if there is a way to install or move these games to my 32g mc please share your advice. thanks
You will have to root your phone > partition your SD card > and use apps2sd/links2sd etc
kelvinnhowe
phone is rooted and I have installed links2sd but I dont know how to partition my SD card, any advice?
