Xperia V - WIFI connection - IP
kenosisaeternum
Ive Read the WIFI topic, and i tried much of the things writed there but i can resolve my problem,
I have problems in connection of my new sony xperia V, i think what is my problem, but i am unable to resolve, or i do not know i can resolve it ...
In my router i only allow the wifi connection with macaddresses saved, but it need a ip too ...
the mobile identify the router but cannot connect with it, i used static and dhcp, its the same results, the pass is corrected... - errmmm i cannot see if the mobile had any problem cause in my buyilding anyone have secured the wifi...
tips for passing this... someone can help?
exist any manner that i can give a ip in other place?! (not when making connection) ?
Rickard
Master
Not sure i understand you correctly but if you don't use DHCP on your router you need to set the phone to a static IP. Go to Settings -> WiFi and tap and hold on your network and then select Modify network -> Show advanced options. Select Static instead of DHCP and then enter the network setting you use.
You also need to allow the phones MAC-address. You can see this from Settings -> About phone -> Status.
2 REPLIES 2
kenosisaeternum
LOL even with no security the mobile do not allow the entrance thats weird ... its to much for me uderstand why the mobile didnt connect ... anyway, any time that conect tothe router, the wireless signal on the mobile most of the time falls to very low... thats weird... 😐
Rickard
Master
