xperia V lt25i led notifcation is not working after phone reset
k119
I have reset phone my and led notification is not working. Battery charging is fine(red->green). But for app notifications, miss calls, sms.. etc its not working.I check for updates but it says upto date.
I enable Liight flow lite, but no luck. tried with some apps on play store no change.
lt25i
Android 4.1.2
9.1.A.1.140
as I depend on this much, now its realy difficult.
Please help.
Kasun
Galeo
I had the exact same problem with my Xperia V and have been looking for a solution to solve the problem without having to reset the phone.
I finally found this widget which fixed it for me:
https://play.google.com/store/apps/details?id=com.motorola.ledwidget
Just install it, add it to any home screen and enable led notifications.
Hope it works for you too!
6 REPLIES 6
Do you have any battery saving app and/or settings?
LoGa
no i do not
and i deactivate extend standby mode
You might want to repair your phone with
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
k119
I tried with several apps, and reset once more but no luck. Update service doesn't list Xperia V. Any idea? Still notification bar is not working. Only worked while charging battery.
Oh man. really fed up.
Galeo
k119
Thanks bro, it worked. Motorola led-widget is the solution for Sony xperia v issue.
