Hi Recently i Tried to Update Sony Xperia u ics 6.1.1.B.1.10 to 6.1.1.B.1.54 with PCC as well As sus and it is showing an error and one of my friend in this website suggested me to download the ftf file and flash it and i did it and it worked fine for 5days and now i getting touch problem...if i touch back option for 5times it breaks for atleast once in every touch...and some times keypad also doing same thing..and i have noticed this is temple run 2 while playing the game i got a left turn and when i tap from right to left it doesn't do any thing !!! so please help me !! and im from india and i tried to update to indian firmware 6.1.1.B.1.54!!! please help!!!!!!!
service centre people are saying that your mobile doesnt have calibaration and its not an indian mobile!!!we cant help!!!!
You are welcome my friend,come again on the forum,without problems of course.Keep us updated with the phone overall progress.
ya sure definately ill ry to come without problems...if service centre people does my mobile repair under warranty!!any way thanks!!!!
Thanks,nice way of thanking me!
excuse ppl...can i have your software version of ics by dialing *#*#7378423#*#* and in the service info ......please its urgent!!!!
bro just given @ service centre....they said thats the mobile problem.....
first they reinstalld the software..but no use then they said we will change the touch digitizer and it takes upto 20days..so i give it!!!!
Hey Guys, I'm confused.
My Xperia U starts with this touch problems after having installed the 4.01. It worked fine when it was 2.3.7. But a msg appears on my desktop, telling me to upgrade. I did it and now it is slow and hard to use the virtual keyboard. Also taking pictures is a extrenuous process.
Question: if it is only a software problem, after Downgrading to 2.3.7 shouldn't the Xperia U work fine again?
I did the downgrade and it still has a touch issues.
Does anybody know to fix the problem? Could the problem only be on the software of the touch? Is that possible to change the defective touch software for one that we know works good?
Thank you in Advance
Carlos - Brasil
Visit a sony service,not the downgrading fixes issues.
Alexdon, you're great. tahnk you for the advice.
I was postponing this cos I thought it was only a matter of bad software...
I'll try more to understand how the 2.3.7. works and send the U to the Sony Service. It is far from where I live (I live in an Island called Santo Amaro Island) but if I have the chance to go to the Capital, I'll find the Sony Service Centre.
Thank you. I hope I'll come again her with better news.
Carlos, Brasil
