Xperia U downgraded to 2.3 - battery charging but stuck at 2%
DariaPahlavi
So after many problems with 4.0 on my xperia U, I took it to carphone warehouse and they repaired it and downgraded to 2.3.
the phone is working perfectly but I've been charging for an hour and it's stuck at 2%?
is this normal?
will I need to keep it on charge overnight or something?
What do I do to make sure it's charging properly?
You can repair your phone or reflash it
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
2 REPLIES 2
PC Companion (PCC)
Bridge (for Mac)
SIbtain7
Hi. The same problem happened to me. When you charge it, it says 2%. But after a few minutes, it rises up slowly.  Remote
