So after many problems with 4.0 on my xperia U, I took it to carphone warehouse and they repaired it and downgraded to 2.3.
the phone is working perfectly but I've been charging for an hour and it's stuck at 2%?
is this normal?
will I need to keep it on charge overnight or something?
What do I do to make sure it's charging properly?
You can repair your phone or reflash it
Bridge (for Mac)
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
Bridge (for Mac)
Hi. The same problem happened to me. When you charge it, it says 2%. But after a few minutes, it rises up slowly.
