Xperia TL Alarm not Working
Braddington
Hello everyone,
My Sony Xperia TL's alarm is not going off whne it is suppossed to be going off and i cannot figure out why. The alarm was suppossed to go off today at 7:00 A.M. EST but nothing happened. I checked the alarm settings and the alarm sound worked and volume was at maximum with the haptick feedback for "Active during silent mode" being on positive. Any ideas?
Alexander1
Champion
Strange! Try to clear data for the clock application under settings > apps>  all > clock > clear data. Restart the phone and try to set the alarm and see if it's going off as it should.
Alexander1
Champion
