xperia tipo dual stuck on sony logo
sankysanky
My tipo dual is stuck on sony logo...please help me recover my phone...i tried flashtool..but it says device not identified...it has tipo in the list but not tipo dual...please help me...
Thommo
Try to perform a system repair
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
3 REPLIES 3
Thommo
sankysanky
i did it alresdy..but thanks for your advice....
Aryagupt
I'm having the same problem and nothing is working.
I've tried emma, flashtool and pc companion, its really stuck on the sony logo plz do something about it.
