Xperia T3 is NOT charging nor connecting to PC...
Peter_121
Hello,
           I am using Xperia T3. I was using my phone when charging in Night. Suddenly in a movement, it stopped charging at 13%. After that my charger is not working on this device. I tried to connect it with another charger. But the indicator in the charger goes off when I connect Xperia to it. But back glowing when i disconnect it. Not that too... When i connect it to PC, the entire board in PC that works shut down and comes back on disconnecting Xperia T3..
           I hope i will get a sollution to the above mentioned problem....
        Hopefully...
        Peter K Joseph
        An Xperia T3 user
3 REPLIES 3
@Peter_121
Test a different cable if you haven't but this might have to be inspected by your Local support.
Could you elaborate on this part:
@Peter_121 wrote:
...Suddenly in a movement, it stopped charging ...
Peter_121
Are you kidding me.. I tried it.. I gave it to ther service center and what they told me is that mycharger bot got problem... An OVER VOLTAGE struck my system and the funniest part is that I am using a Sony Chager. It stopped working and the phone too.......
Peter_121
I was on my bed. Well that partis.. ee.. I just woke from there.. But i got sollution. It's the problem with it's charging board. Well the funniest part is that i am using a Sony Charger.
