Sorry to hear about your phone.
I recommend that you first try another USB-cable to check so it's not the cable causing this.
If the same thing happens your phone needs to be repaired. I would not recommned that you try to fix it yourself or let an unauthorized service location do it.
Based on your account, you're located in Poland? If so, you can order a repair directly from www.sonymobile.com. See this thread for more information: http://talk.sonymobile.com/t5/FAQ/How-to-get-your-Sony-Xperia-product-repaired/m-p/991374
Oh, I feel so stupid now, changing the charging cable actually worked, there's no problem at all. I thought it was a socket problem and I panicked, before thinking of trying to do a simpliest thing 😕 Thank you a lot, greetings
Glad to hear that issue was not in your phone and that it works now
